I am just about to install my new Stoves Richmond 1100E Induction Range Cooker and I am not happy with the electrics.
My father in law "Qualified Electrician" did all the electrics before the plastering and I told him it was a 45 Amp Cooker.
After he had fitted all the elecrics I quized him again and he said he installed, I think a 32 Amp Switch Unit. The breaker in the Consumer Unit is BS32 32Amp??
I have just had a look at the sticky on this Forum and the cable looks as though its 6mm2 (The dimensions are 13.5mm x 7mm), on the cable is printed BASEC 078 BS 600 6242YH 2x6+2.5 PX 42.
The Live and Neutral Cores are about 5mm.
He had a look in the 17 Edition Handbook and worked out that the installed electrics would be OK and added that it would only draw 45 Amps if everything was on MAX!!
Should I go with his thinking or call in a second opinion, I assume that the Switch Unit and Circuit Breaker will be a direct swap but the cable will have to be re run all the way back to the consumer unit??
If I stick with what I have all that would happen is that the circuit would trip wouldn't it??
Ta
Ta
