Not strictly electrics but here goes...
Just bought a house and the family bathroom has a fan (not timed) that spurs off the light, ducts into the loft and out through a hole in the gable end.
Next door, the ensuite bathroom has no ventilation and gets very humid as we use it most.
As the two rooms are adjacent, is there a solution whereby i'd install a fan in the ensuite using the existing hole in the gable end for both outflows? I've drilled 4 inch holes through masonry before and don't fancy doing it again. Does it mean both bathroom would be ventilated when the light was switched on in one of them?
