Hi
I am going to install a 10.8kw shower. I have been getting contradictory advice as to size of cable and fuse rating. Can anyone help? I was going to install using 10mm T&E and also fit an RCD. I was also going to use a 45A fuse at the consumer unit. I have found on certain sites that i should be using 16mm T&E and it should be governed by a 50A fuse. There's no way i will get 16mm into the shower unit. The consumer unit is rated at maximum of 63A. The length of the cabe le run is approx 15 metres from CU to pull cord switch. Any help greatly appreciated.
