Hi
I am about to install a new bath and want to put in a combined filler/waste in the overflow similar to one of these http://www.crosswater.co.uk/files/CRW_bath_filler_wastes.pdf
They all mention being used with a thermostatic shower, however I won't be putting a shower over the bath. Can I just run the hot and cold from taps drilled onto the flat top surface of the bath using some sort of t-piece brass-wear under the bath or do I need to have a thermostatic valve mounted on the bath or wall?
