I've read already some posts addressing this topic but most of them are about installing a boiler onto plasterboard without any insulation behind (just a void of 2-2.5cm...
In my case there is a 40mm urethane board (Celotex, Kingspan type) between thermalite blocs (the wall) and the 12mm plasterboard....
I've come up with the following solution:
Drill the thermalite blocks and install some resin fixings (e.g. Fisher) - these should accommodate the thickness of the urethane board and the plasterboard (and a little more to allow the nut to be tightened) - so the bolts should extend about 70mm from the wall (the overall length of the bolts is going to be around 150mm - 80mm inside the thermalite block).
Has anyone tried something similar to this?
