- Joined
- 12 May 2007
- Messages
- 292
- Reaction score
- 2
- Country
I'm looking to put a small 12" semi flush light fitting in my hallway, i bought a new light but when i got home i notice on the instructions that it says to be hung from a joist. The light weighs 3.5 kg, when i tap around the ceiling i struggle to find the joist. Would all light fittings be generally screwed onto a joist??, if not, this new light has a 6" span on it so i can cut the hole the hole in the ceiling a bit bigger, i could then slide into the roofspace a 1 1/2" x 1 1/2" x 12" piece of wood to spread the load, the light fitting would then be screwed into that. Would this be ok to have that 3.5kg load spread across the plasterboard?, if not, then apart from taking the light back are there any other suggestions.
Cheers
Cheers
