Installing a dual-tech PIR with just 6 cores
8 Jun 2016
I need to replace 4 sensors on a zone that occasionally false activates. I have bought Honeywell Activ8 AM-DT anti mask quad PIR and Microwave sensors, but they appear to need 8 cores back to the panel. Because this is a retrofit, I only have 6 cores.
The installation instructions refer to this wiring configuration:-
Terminals 1&2 = tamper circuit
Terminals 3&4 = R-AM (output relay Anti Mask contacts of the detector. Connect to a normally closed zone in the control panel).
Terminal 5 = End of line option
Terminals 6&7 = R-PIR (output relay PIR contacts of the detector. Connect to a normally closed zone in the control panel).
Terminal 8 = +12v
Terminal 9 = GND
Is there an easy way of connecting this back to the control panel with just 6 cores by using jumpers for example?
Yes, you don't need the anti mask unless your installing to grade 3 , as a diy you won't ...
