Installing a Heated Towel Rail?
28 Apr 2007
Hertfordshire
I'm thinking about installing an electric heated towel rail in my bathroom but just want to make sure it's a job I'll be able / know how to do .
Can anyone give me a quick guide? Also is it ok to tap into a plug socket outside the bathroom for powering the rail? ie.
Wiring
Towel Rail -> Switch outside bathroom -> tap into plug socket wiring
Is this job do-able for someone with good DIY skills?
Many thanks
You would normally take a fused connection unit spur from conveniently located socket outlet on the Ring or Radial circuit.
If the socket you spur from is part of a ring final circuit, the supply feed cannot be taken from a socket that is already an unfused spur.
You will also need RCD protection for the equipment in the bathroom and certain requirements of building controls notification may need to be complied to, as deemed a location that requires this.
Also there are zones within the bathroom and complaints electrcial equipment and accessories must kept and zones were cables can be routed safely.
Links below:
//www.diynot.com/wiki/electrics:part_p
//www.diynot.com/wiki/electrics:speclcn:bathroom_zones
//www.diynot.com/wiki/electrics:installation_techniques:walls
//www.diynot.com/wiki/electrics:installation_techniques:route
Thanks for the help, but I don't know even know what a spar is - so probably not wise to attempt this!
So I'm going to replace my radiator with a heated towel rail, as this should be much easier!?
Spar? Is a bath or an outlet to buy food, drinks etc.. It's a spur!
Probably right then.
If this an electrical appliance, I refer back to this:
Thanks for the help, but I don't know even know what a spar is -not wise to attempt this!
In your case, it would be a wise move to employ an electrician.
Who's confused here?
You wanted to install a heated towel rail but
have been dissuaded by the advice and
have decided to install a heated towel rail instead.
EFLI,
I assuming (which I shouldn't)
That the OP has now turned to his plumbing skills, as they lack the ability not only to understand the advice given but to be able to follow it!
Yes, I'm going to plumb it in. It'll be easier to replace my existing radiator with a towel rail.
Cheers
Spar? Is a bath...
No, that's a spa.
A spar is a longitudinal structural member of an aircraft wing:
Cheers
What will happen in the summer when the CH is not on?
The same what's happens now..... sits on a cold radiator & get air dried!
So why bother changing the existing radiator for a towel warmer?
I want a rail that can hold more than one towel. I know I can get a normal wall rail but I've got a very small bathroom & it'll be too much going on. A decent rail will cost around £50+, so I might as well get a nice heated one!?
I'm pretty sure I'll be able to plumb it in, the filling & drilling won't be a problem! So might as well give it a go...... whats the worst that happen - flood the house!? ha
I don't really want to play around with the electrics when I havent done so before!
