Ello, I need some advice for my next DIY project - Installing a cooker hood with out destroying the house.
Heres the problem. If you picture the cooker in front of you, the only wall I have leading outside is to your left - So the hood needs to be attached to the wall opposite you and the ducting needs to run out of its side along the wall and through the wall on your left...
I was looking at a chimney hood, but how would I run my choice of ducting out of its stainless steel side? Does the ducting run out of its TOP and then left towards the wall leading outside? Or is a chimney hood only good if its mounted on the wall its running through so it hides the ducting?
As you can tell I've never installed a cooker hood before, i'll be fine installing the fuse box I just need to know the best way to connect a hood to my outside vent using a rectangular duct, any suggestions?
Cheers.
Cheers.
