I have just had a Combi installed and as a result my current mixer shower is now only pumping out hot water. I have bought a new Thermostatic Mixer to replace my existing one. The measurements seem to be the same and they are both exterior fitting so I assume it is a straight replacement ! Can anyone advise my on how easy this job is ? I believe I have to stop the water supply, open the taps in the kitchen to drain the system and then unscrew the old mixer and put on the new one ! Is it that simple ? Will it effect my new Combi in any way if I empty the water supply ? Do I need to switch it off atall ?
