installing a rsj
13 Mar 2010
Bedfordshire
i want to open up my kitchen its a single skin of brickwork 11 foot long above a non load bearing wall its 12 inches away from the wall above how much would you suggest either side of the rsj and would i get away with a timber beam or something liter cheers for any ideas
You mentioned a non-load bearing wall but you're also talking about installing an RSJ. So... is this wall your removing load bearing or non-load bearing? You may require building regulation approval and if so, they may ask for details/calculations of the proposed beams, which would also provide details on the bearings either end.
I've put the OP through google translate, but still can't make head or tail of it :confused:
