Hello,
I need to install a wall mounted shower pressure booster (Triton T40i) in my bathroom and need some wiring advice. The installation leaflet says that the booster pump needs to be wired using 1mm2 cabling and a double pole 3 amp, fused switch. I currently have an extractor fan installed that is feed from a 3 amp fuse using 1mm2 cabling. Can I change this to the double pole switch and run the shower off it as well or will that cause problems?
I read the shower installation articles and posts but couldn't find any that described installation of a low amp shower pump on an existing extractor circuit so any help will be much appreciated.
Sumit
Sumit
