installing a shower
RKB
22 Jun 2004
Been asked to install a shower in mother in laws.
System is a none combi, with cold feed from loft tank (so hot and cold at same pressure).
If I was to recommend a good thermostatic mixer (any recommendations?), could I just not tee off existing hot and cold supplies in bathroom?
Or do I have to get involved with essex flanges?
Thanks.
Yes you do, but only if you want to do it properly :) oh and don't forget the new suply from the cold cistern
Thanks Artful,
Can you explain the "new supply from the cold cistern"?
Hi Kevplumb,
OK, I understand the reasoning.
What is thge best way to connect a supply from the cylinder feed tank? Do you actually tap into the tank (is there a fitting to do that?), or feed off the line out of the tank to the cylinder, i.e. into the existing pipe?
Thanks..
If it's from the loft to the floor below, you'll have a piddling shower unless you pump it. Easiest is probably a pumped box-on-the-wall like an Aqualisa Aquastream (£300+) or a Mira (£less) or a NewTeam (£130?)
Thanks for the suggestions.
If I was to go with an "all in one" solution, which was mains driven, would I need to get a sparks in to install it on a dedicated RCD at the CU. Or can they run of a spurred FCU /RCD, so in the airing cupboard on the landing?
