I have a bathroom sink that I can't get the waste to seal into properly. It is a Wickes pedestal sink, and I am using the supplied 2-part pop-up waste.
It came with 2 washers and I tried using them with some genuine silicone, but it still leaks. So, I have taken the sink off the wall and removed the waste and silicone. Now to refit the waste!
Just to make sure I have got the right washers with my waste: there are two, both white rubber, identical. Not foam.
What I did was:
1) put loads of silicone in the contact area between waste and basin
2) slipped the first washer over the waste
3) pushed it through and moved it around a bit to get rid of air.
4) put a load of silicon on the underside of the basin, where the second part of the waste would contact it.
5) Then I slipped the washer over the underside of the waste where it poked through the basin
6) tightened the two halves together by hand, no spanner.
Now, I did it up what I thought to be quite tight, but it was only by hand as I didn't want to crack the sink.
Did I do this correctly? Should I have used a spanner? Are there enough washers?
Thankyou!
What I did was:
Thankyou!
