Installing a window into a new wall
26 Sep 2008
Staffordshire
Hi,I'm extending my garage,the new walls being built a half brick thick,and I have a couple of used UPVC windows that I'd like to fit.
Should I build the wall around the window frame,or make up a simple timber frame of slightly larger dimension,and then fit the new windows after the wall's built?
I wouldnt bother with a sub-frame just build around the existing.
You will need to put some packing around the frame for expansion ... 3-5mm hardboard is useful.
Don't build it tight to the frame
I meant a timber frame as a "pattern" for the uPVC frame,to take out after the wall's built and then slip in the uPVC frame and fix it in with masonry fixings.
Are you saying I should simply prop the uPVC frame in the desired position and the build the brickwork up to and around it?
Yes, and I think Alastair meant that too
Why make a dummy frame when you already have the proper frame?
Oh, and put some hardboard or cardboard or something on the cill too, to protect it
Hi,thanks for all the replies.
Should I use those little galvanized frame fixing brackets that screw to the sides of the frame and are cemented inbetween courses,use something like hammer fixings,or with the mortar hold the frame securely without all that?
I was also wondering whether I could fit the windows so that they're flush with the top of the wall so I don't need lintels - or would that make for a weaker wall?
Frame cramps are for timber windows. Plastic need fixing after the wall is built with the proper fixings. You don't need lintels if there is no roof weight on them.
