Sorry guys another question on electric hobs. I am replacing a gas hob with an electrical one. The existing radial circuit comprises of 30A mcb at the CU with 6mm cable to the CCU and 6mm cable to a normal 13amp double plug socket behind the cooker (all that was needed before was a socket for a 2.5 kw oven and the ignition for the gas hob). I will of course replace the double socket with a terminal connection unit for the hob (6.2 watts) which I will connect with 6mm tce. My question is how do I connect the oven? Can I take a spur from the tcu and connect a single socket for the oven plug? Any advice would be much appreciated. Thanks
