bought an outside light which i thought was solar powered but its not.
im not a complete novice with electrics....i have run extra sockets from another socket, changed light switches, but thats about it.
im also looking to make as little mess as possible.
i have a plan ! but wanted to run it by someone who knows what their doing first.
on the wall i wish to install it, there is already a sky cable running through the wall, say a foot or so from the floor. i plan to use this hole to put the cable through, save drilling another. inside the house there is a plug socket just 2 feet away that has very little/no use.
can i wire up the cable direct to a plug and just plug it in the socket ?
or run the cable inside, then up the wall to a switch then back down the wall wired to a plug ?
or as above and wired properly into the circuit via the plug socket ?
i have a real of cable left over in the house. which im 99% sure is up to the job, its the same size as lighting cable, but not sure if i can use this externally as it would be open to the elements for a good 2/3 meters running up the outside of the house to the light.
thanks in advance for the advice guys !
