- Joined
- 16 Jan 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi, new to the site so hoping someone can give some advice.
Just had windows and roof removed from old conservatory in prep for replacement windows and roof. There is no insulation within the cavity and I have been told that if I put some insulation such as celotex into the cavity it will improve the insulation within the room.
Have looked at the celotex site and they advise that the boards need to be clipped against the inner leaf of the wall using the wall ties and retaining clips. However, the walls are already built and one of them is 2m high so this wont be possible.
Is it acceptable to simply drop the boards into the cavity and let them sit loose? Not looking to make the insulation perfect, just an improvement on what it is! Would loose fit simply reduce the thermal efficiency, or does it cause other problems with condensation etc?
