It's an internal load bearing wall made of old 190s blockwork and our SE has specced a 65/100/1200 lintel with 150mm bearing onto blockwork either side.
I've only installed lintels into non load bearing walls before. Can I just place the lintel onto the bearings with mortar between or do I need to replace a brick either side with an engineering brick or even make a padstone? I've also seen talk of using slate to take the bearing weight. What's the proper way of doing this?
