Hi guys im wanting fit some decorative pvc cladding to my toilet room at my work premises but after removing the previous very tatty suspended ceiling, Ive realised there isnt any real ceiling work above. It is just the underside of the roof i.e. insulation. So basically the room was as such where once you walk in, there is approx 2.7 meter distance from floor to the suspended ceiling.
Now however on one side it is approx 2.9 meters and around 3.6 meters on the other as of cours the roof slope is exposed. The room itself is made up using timbers studs and the frame is higher than the previous suspension.
Likewise my question was, what on earth would I need to do to fix the panels approx 2.7 off the ground. The only solution i personally can think of is get some battens and fix them across the timber studs and make my frame but was wonder whether it would be a little flimsy in the centre considering the toilet toom is 3.5 x 1 meter. Also what size battens would I need if I was to do this and also whether any recommendations as to how far apart i need to set these batten. The panels btw are the standard 3 foot or so panels
thanks
thanks
