installing downstairs toilet - venting stack question
28 Apr 2005
Sussex
I am putting in a downstairs toilet but it doesn't connect to the existing vented stack that my upstairs toilet connects to. Instead the waste pipe runs under the floor directly to the inspection chamber of the sewer where the current stack connects to.
The new toilet waste pipe is about 3 meters from the toilet to the base of the inspection chamber and the lowest part of the toilet ubend is about 60cm higher than the base of the inspection chamber.
My question is, do I need to install a vented stack for the new toilet? I can do this with a durgo and some 110mm pipe in the downstairs toilet (above highest appliance flood level and boxed in) but it takes up a lot of space in such a small area. If I don't need to vent it then I save precious space
What are your thoughts guys?
Many thanks
That would be Approved Document H:
http://www.planningportal.gov.uk/uploads/br/BR_PDF_AD_H_2010.pdf
See page 7 (or page 9 of Adobe Reader)
Also see page 11 (13 of Adobe Reader) if you have a washbasin there.
No vent stack required
Also consider a WC connector with a waste point for a basin (others available)
http://www.mcalpineplumbing.com/wc-...length-rigid-wc-connector-with-vent-boss.html would need an anti-vac trap on the basin
However, if your drains are subject to flooding then you actually need a full vented stack (not a durgo).
Magic, Thank you Blagard.
So as my new toilet floor is less than 1.3m above the base of the drain (sewer) it won't need to have a vented stack and i'll get one of those WC connectors with the vent boss to connect the sink to and get a trap for the sink with an AAV on correct?
