I need to add a fair bit of fencing (200m or so)
It is going to be 100mm round posts (1.8m). With rails.
I need to keep costs as low as possible and don't mind it taking a while to do, but we will need to put 100-150 posts in.
I was thinking about one of the petrol augers with a 4" auger bit. Drill 60cm, then knock the post in. Is this a good way to do it, or would we be fed up after 10 posts? Do they work well and does it leave you with a nice secure post?
I've seen hand powered augers too, but I'm guessing that would be too much work. Someone else suggested using the tool like two spades stuck together.
Would appreciate any thoughts.
I should add, this is in a paddock and is intended to keep horses inside the paddock.
I want thinking of using concrete and it would just be the posts in the ground.
