Installing fireplace/stove in old blocked off fireplace?
9 Apr 2010
Cheshire
Hi. My mum has a terraced house, approximately 80 years old. When we moved in 20 years ago, the fireplaces downstairs contained sideboards and lights at the top and upstairs were plastered over with vents. When the house was renovated, the vents were removed upstairs and downstairs was plastered over and vents inserted.
Mum asked the builder whether a fireplace could be installed and, according to mum's memory (unreliable) he said no because the chimney was damaged or because it had been closed off. There are vents in the downstairs rooms, presumably connected to the outside via chimneys. Surely it must be possible to put a flue along the inside of the chimney and a gas or multifuel fire at the bottom?
How much do you reckon this could cost? Mum's managed to save £1500 so far. Unfortunately, this is a project that I wouldn't be comfortable with attempting, but maybe there's something I can do to make the project cheaper.
There's nothing to prevent your project per se, but the flue will definitely need a liner, and its access for that which is the prime issue.
Its definitely a job for the pro's, this one, who will do any installation to building regs, including ventilation, spill tests and the rest.
Presumably there's also a gas pipe to be laid.
Personally this isn't a job for cutting corners.
John :)
Okay, thanks a lot John.
Mum wants a gas-fired stove but we wonder whether it would be possible to find one that can also burn wood? Do such combined stoves exist or is it a choice between either gas or wood?
So far as I'm aware, there isn't a stove that will burn gas and also wood - at least for domestic applications - but I really don't know.
At this point, maybe someone else will come in!
John :)
