Installing french doors backwards in loft conversion?
5 Feb 2007
London
Hi all,
I have a plan to include a pair of french doors and a juliet balcony in the new horizontal dormer wall. Trying to find a set of inward opening doors is somewhat difficult. Is there any logical reason i can't purchase a standard set of french doors and then install them backwards. I've had a look at the following pair up close;
http://www.wickes.co.uk/invt/158308
There doesn't appear to be anything preventing the inside to be outside. Any thoughts? Or does anyone know where i can get an inward opening pair (in the same price range!). Thanks
heeelllooo red lagoon :D :D :D
door sits on the front of the frame water hits the glass and frame and runs down the face edge any water that gets behind door seal fall out the bottom harmlesly any water that gets between glass and door comes out the drain holes at the bottom of the opening
if the door opens in the way any water hitting the glass and bypassing the rubbers gets pushed inside with the only form of escape being internal
you can get inward opening doors but once rubbers stop being 100% you get leaks
I do know where you can get them........... :rolleyes:
But it would be self promoting.......... ;)
big-all:
Doh! Thanks for that, can't believe i forgot something so obvious.
The-brickie: I've googled your name and it brings nothing back, so the self promotion isn't obvious enough yet!
