Installing Horstman DRT1 digital thermostat. No/low voltage?
11 Oct 2006
Lancashire
Hi All,
I'm installing a Glow worm 30cxi, with Glow worm timer (if I'd have found this site earlier I'd have probably got something different! too late now as it's delivered & the pipes connected to jig, ce la vie)
I've bought a Horstman DRT1 digital room thermostat. It is battery powered & the manual says it can be used on mains or "low voltage".
The 30CXI has "No Voltage" connections for external controls, as well as a mains connections.
I'd be really grateful if someone could tell me if the Horstman will work on the "no voltage" connection? Or if I would do any damage connecting a battery powered device to the "no voltage" connections to test it?
Cheers
Don :confused:
You try to impress by using a foriegn phrase, but spell it wrongly! C'est la vie!
You can use the voltage free switching on the stat with your boiler. Pas de problème.
