Please excuse the simplicity of this question, I'll admit in advance to being a bit of a diy dimwit
I want to replace two eurolocks in a pair of connected upvc doors. The instructions say to open the door, remove the retaining bolt and slide out the lock. Yep, that is easy on ONE of the two doors that lock together but not the other...
The other door has a upvc connecting piece about 60mm wide that runs the length of the door, held in by about 6 screws which screw into the edge of the frame of the other door. Needed to ensure no gap between the two doors. This piece covers the edge of the door, preventing access to the eurolock retaining bolt, so clearly has to be removed.
After removing the 6 screws I couldn't easily remove this connecting piece and don't want to force it for risk of breaking it.
Do I now need to slide this piece up off the door or should it simply pull away from the door frame?
There also appear to be 3-4 metal U shaped plates between this upvc piece and the door frame, any good tricks on how to keep these in place when refitting this piece?
Thanks...
Thanks...
