I want to install a wall-mounted fan (with timer overrun) in my house and want it to be switched independently from any lighting.
I would like to make the installation by using a DP SFCU and separate 1 way single pole switch and have made a sketch of how I think this would work.
I plan to take a spur from the main ring (which originates at a 30A MCB which, in-turn is RCD protected at the CSU); the initial spur cable will be 2.5mm T&E as per the main ring and this will terminate at the DP SFCU which will be fused at 3Amps. Between the SFCU and the single pole switch, I will be using 1.5mm T&E; because the fan has an overrun timer, it requires a permanent and a switched live so I plan to use 1.5mm 3 core and earth between the SP switch and the fan.
The permanent live and switched live will be obtained at the SP switch, the neutral for the fan will be achieved by connecting the incoming neutral (blue) to the outgoing grey (sheathed blue), this connection will be via a terminal block in the SP switch pattress.
Will this work?
[/img]
Will this work?
[/img]
