installing pipes underfloor
6 Feb 2010
Blackpool
I'm installing some central heating pipes under floor ,I have cut a trap, the main run, runs the way the joist are runing. Am I ok cliping 2 22mm pipes to this or best of putting a bit of 2x1 between this to make a kind of bridgeing then clip to this.
No problems with clipping pipes directly to the joists - use the plastic type rather than the saddles so you can get the insulation round.
Its a good idea to mark on the floor where they are for the future, and keep the pipes down a bit to avoid the errant nail, etc.
John :)
This is not the mainstream method but you could consider suspending the pipes below the joists a little on string/cord/tie-wraps.
This has the advantage that the insulation is more effective and easier to apply and it also reduces the chance of clicking noises as the pipes expand on warm up and cool down.
Tony
ok thanks for response but if clip to the bottom of the the joist all the way across, as the pipes run the same way as the joist, with nail in clips don't think I'll get any insualtion on that's why I was thinking of puting some wood between the joist.
You can waste up to about 5% of your heat with uninsulated pipes through an unheated floor space!
Only an ***** would not spend £10 on insulating the pipes! The cheap stuff at Wickes is about 60p per meter!
Tony
Is it a ground floor or a first floor :?: Talon clips with extensions will space enough for lagging :idea:
Its ground floor Have cut a trap in the floor so I can get underneath the floor. I have about over half a meter height under floor so isn't so bad
