installing pitched roof on conservatory
17 Sep 2014
Norfolk
I have finished bricking and blocking up my two skin brickwork conservatory up to plate height of my bungalow. I had building control out to check the foundations of the existing structure and unfortunately as suspected they are not suitable to take the load of a pitched roof. The roof was a glass paneled roof previously. Therefore I have started to underpin the front wall of the structure, digging out at the moment. I have hit sand and gravel around 600mm under the existing.
There are two main technical parts to the build:
1. I have been told that I can support the new roof by using two beams supported from the block work of the now supported front wall and the bungalow. This will save underpinning the other two side walls.
2. The extension will be opened up into the kitchen. Therefore I would love to have a nice flat ceiling between the two rooms. Therefore I need to support the trusses of the bungalow and the two new beams for the new roof on one beam. The trusses will be cut back and hung off truss hangers. The two beams will be hung off the same beam at the same height as the bungalow trusses.
Has anyone had experience or general advice on these next stages?
