Installing PVC Wall Panels in Bathroom
29 Dec 2006
Edinburgh
I am looking into installing PVC wall panels in my bathroom that is partially tiled with mismatched tiles, rather than taking the old tiles out and putting new ones in.
I cant find much information from sources other than the manufacturers. So I have lots of questions
1. Are they really as easy to install as the companies claim?
2. How is the look and feel, I'm looking for something celan, crisp, and new, nothing fancy, but I dont want it to look like a hospital bathroom
3. Does anyone have any particular recommendations for companies?
4. How does the ceiling paneling actually hold-up -- I'd be afraid of it falling off?
5. Can you put them on the floor? or alternatively is there a company that does wall, celling and floor that all matches?
6. I'm looking at www.fascias.co.uk, anyone had any experience with this company?
thanks
Lindsay
Do you mean this :?: If not, can you tell us where about on that link
MARBREX.........`kin brilliant stuff..did my shower room with it ;)
Still can't see it :oops:
If you type in shower wall panel in google, plenty there to chose from.
Here one of them
Masona,
thanks for your persistance,
if you are still interested in finding the facia.co.uk ones, I think it will work to go to the site and do a search for "bathroom"
anyway, I did look at the site you suggest, but I'm still no further forward
-- any idea anyone as to what these look like in a bathroom, are they cheap and plasticy or are they much the same as tiles in appearance, do the ceilings start to sag eventually
Look good in my house .....that`s virtually the same as the Marbrex I used from a local supplier....ceiling is fine too
Okay, I’ve seen it now
Looking at the fixing guide, you will need to batten all round the room & ceiling (if needed) I would say a minimum 2"x1" timber, so your room size will be reduce about 75mm in total. I haven't read it all but the door frame will need some external edge moulding & also the bath, basin, toilet will need to come forward to allow for the batten with the cladding and this could where it will be fiddly to do.
The panel width is 250mm and you will see loads of line where the joint is I would've thought, poor picture to see although you can get a free sample. Make sure the floor to ceiling is no more than 2.6m
There are loads out there so I can't comment on them
The same way as we do upvc cladding, nails, staples or clip onto the batten.
I would say no as it will break or crack and it would slippery.
I haven't but I do know people who has and are happy with them but does depends on what you're buying, best to ring them or have a look at client room sample if there's one in your local area(?)
thanks masona,
I think using battens is only one option, I think they also say you can use sealant to fix it directly onto old tile, at least on the walls.
I probably would only do it round the bath and not the toilet, but would definitely not consider this if I had to move any of the fixtures
look at Mermaid water proof panels,
they are a little bit more expensive but no studding required, they are also made from waterproof laminate not plastic so are hard, not a bit squiggy like the plastic waffle style.
will look for the website
