I am in the process of replacing my hot water cylinder after the previous one had sprung a leak (over quite some period of time, and now I have a significant damp problem in my airing cupboard walls, but that is another matter).
Anyway, I have removed the old cylinder, purchased a new one and am all ready to install. The only question I have is re the clyinder fittings. The advice I have been given so far is to just use PTFE tape to ensure a seal. I would have thought that also using washers would have been necessary to prevent leaks. What's the opinion on this one?
Also, Are there any clever tricks to get the fittings facing the right way to match up with existing pipework? Rotating the tank only goes so far...
Matt
Matt
