Installing roof joist into header plate?
23 May 2020
Hi looking for advice on dealing with the 2.5m height restriction on a outbuilding. I am building a garden office 4x2 stick frame.
I am looking at installing french doors (2400mm wide) and I underestimated the Size of the vertical header plate required.
If I go for a 8x2 vertical header doubled up, it throws my already tight height calculations off.
I was planning on birdsmouthing the roof joists so they sit on the top plates at either side of the garden office.
However to save some height could I use joist hangers that are attached to the vertical header plates, to hold the roof joists (6x2 over a 3000mm span @ 16” OC)?
thanks in advance!
