I'm going to be installing a new stack pipe as my oid
One will be covering my new doors of new extension. Obviously this will be going through building control as is my extension.
So my question is, there will be a vertical stack which will be vented above roof, this will have the upstairs toilet going into it and also I want to put the bath waste into it. Is there a particular distance above or below the toilet waste I can bring the bath waste in at?
Then it will go down to the ground where I will have a sweeping bend and it will then run under ground in a straight line about 3.5m to a man hole where it will join the sewer. In this under ground section I wa going to put a Sweeping tee piece where I intent to go through the wall back into the house to pick up a new downstairs wc.
And lastly, I want to put the kitchen sink waste into it. Is this also ok?
