I've recently moved into a house with a couple of sockets attached to the loft wall. The cables run from under the floor and up the wall to the sockets. I thought that it might be an idea to stick them into some steel conduit to offer them some protection. What is the accepted way for the cable to enter and exit the conduit without chaffing on the edge on the way out? I note one usually uses a rubber grommet on the entry/exit to a backbox but I've failed to locate something similar as a 20mm conduit accessory.
