Im coming to the end of the long drawn out kitchen refurb Ive been doing (at last) - and will soon be installing the worktops.
Since Im using a Belfast sink, the tap sits in the work surface rather than the sink. Im guessing this would mean that I would need to bolt the tap onto the worksurface before it goes in, and also make sure the feeds to it are attached, and accessible from the cabinet below?
Im a bit worried now in case anything goes wrong with this tap - would I need to remove the whole work surface to get it out!?
Also - in terms of seating a belfast sink, should I be using some kind of silicone sealer between the cabinet and the sink, and then something between the underside of the worktop and the sink? Ive heard some people use grout for this.
