- Joined
- 2 Dec 2004
- Messages
- 552
- Reaction score
- 4
- Country
Hi all,
As part of bathroom refit, I have decided (upon the advice of my plumber friend who is helping me fit) to go for a thermostatic mixer shower off the combi.
If you can imaging standing in the bath looking at the shower end. In front of you is a bare brick wall which will be plasterboarded, skimmed and tiled. On your right is a stud wall which is being built to cover all the central heating pipework that runs down from the loft where the boiler is.
How should the shower be installed and do I need a surface mounted one or a recessed one?
As far as I can see I could have the shower mixer valve mounted to the head wall which would be the normal situation. But I could mount the mixer valve to the stud wall which might be easier. Doing this the valve controls would be on your right as you stand in the bath, with the rail and spray head in front of you.
I notice in the instructions for the shower valves they say that rear access is desirable or a removable panel. I will have neither of these, so is a surface mounted one better? But would I need pipes running external to the wall to do this or do they still run behind?
If installing on the bare brick wall, what depth is required between tile face and wall. Given that the wall will be drylined, skimmed and tiled. What amount of chasing out of the brick would be required?
Many thanks, I know this is probably one of those situations where pictures would help and I will try to post some when I get home later.
