Hello one and all
Firstly i am new to these forums so ill start with a big hello to everyone on here. No doubt you will see me quite often asking question after question hehehe.
Anyway, on to the subject at hand...
I am installing TV wall sockets into each bedroom and the living room in my house. It previously only had a coax straight into the living room and main bedroom. As it was setup before I had a good signal in the living room and main bedroom (it had a booster in the living room with a straight coax going out, through the loft and into the main bedroom, no sockets). I have now moved the booster into the loft, wired the antenna straight into the booster and run a coax to the main bedroom into a wall socket. Now I can get very few digital channels in the main bedroom and those I can get are only poor signal quality.
I am assuming this is because of signal loss in the wall socket as that is the only difference, the booster is actually a lot closer to that room now (in cable length) !! I am only using fairly cheap sockets that I bought from Homebase, this may be a problem.
Can anyone give me advise if there are better sockets to use or if there is better coax I can get etc.
Any information would be greatly appreciated.
Thanks in advance.
Thanks in advance.
