I am just in the process of having a new kitchen 3m x 9m on the back of my house.
I brought an underfloor heating system a couple of months back when the floor was being laid
http://www.underfloorheating1.co.uk/product/standard-2-port-kit
I did a bit of research and found that for the size of the room 2 circuits would be better, due to the length of the pipe runs, the pipes are laid on 100mm insulation board with a suitable screed on top.
I am now getting to finishing the electric and plastering etc and Ive realised that the kit didnt come with any means of control.....I was in a bit of a hurry when I brought it as the screed was booked and I had not sorted the UFH!
The kit has a pump and a manifold, but I need to understand how to drive the pump.
The rest of the system is radiators driven by a combi boiler. The boiler just uses the standard integral timer/programmer that comes with it and a wireless thermostat.
There is a wiring diagram with the kit, but this is not at all clear.
Can I keep my existing room stat? Do I need a second room stat for the kitchen to switch the pump on and off? Do I also take a feed from the boiler/timer so that the pump only cuts in if the CH is working on the boiler? Is there an off the shelf control unit that can do this?
