Aspira Inline KL 10/4 T with electronic timer that allows the fan to work normally when the bathroom light is switched on, providing a programmable delay function when the light is switched off.
Unfortunately the plumber was an unqualified crazy fitter and did not understand the wiring, paid in cash he took the instructions and lost them and refuses to return. The fitter has the three numbered fan terminals connected to the pull switch as follows:-
No.1 was wired brown, No.3 was wired blue and No.2 has no wire at all with the cable earth wire chopped off.
I have searched the net and found you do need all 3 fan connections.
Quote
The extractor fan needs wiring to the bathroom light via a triple pole switch, this disconnects the live, switched live and Neutral.
TERMINAL 1 = SWITCHED LIVE
TERMINAL 2 = PERMANENT LIVE
TERMINAL 3 = NEUTRAL
The three wires from the extractor fan should be wired as follows-
Triple pole TERMINAL 1 TERMINAL 2 TERMINAL 3
Fan SWITCHED LIVE PERMANENT LIVE NEUTRAL
Unquote
I need my bathroom working and I am willing to ask a friend to fit to avoid more cost to myself, and have sent an email to Aspira in Italy for the wiring without any luck.
Can anyone please help me, if I can obtain precise instructions, in particular about connecting the light switch live and neutral to the triple pole unit and the need to use earth wire as a “Live”.
Quote
Unquote
