Instant Hot Water advice needed please.....
13 Mar 2010
Kent
I recently posted on here regarding the fitting of a water pump from my hot water storage cylinder. From your replies it appears that because I have a "Fortic" or combination storage tank I am unable to fit a pump for the hot water to the kitchen tap.
My next question is this, I am now considering fitting an electric water heater that runs off the cold mains, to provide hot water to the kitchen sink only.
I am looking at the "Wijas Perfect 50" and was wondering if anybody has any experience of these, and whether it would solve my problem.
This is the item in question........
http://www.heatandplumb.com/acatalo...arch&utm_medium=GoogleBase&utm_campaign=Feed1
I live in a small 1 bedroom flat, and have an economy 7 combination cylinder. the pressure from the tank feeds the bath and basin taps with no problem, but the kitchen sink suffers from very low pressure, (almost no pressure).
I am hoping that this will work as it is fed off the cold water at mains pressure.
Reading the details on this heater, its water output isn't too special ( 3ltr/min max @ 32deg c ), will this be enough for your needs? Also, I do believe you will need to run a seperate radial electric supply to this heater, as its rated at 15 amps minimum, so would almost be treated as a low power electric shower? Leccies will back me up / crucify me on this point :)
I can see no reason why you should not pump the output from a combination cylinder as long as you do not use so much water that you empty the top storage part.
It should not be confused with a Primatic cylinder.
Tony
