We had a Triton T80i shower unit fitted in the en-suite bathroom a few years ago. It has always given problems and is a real pain as the water temperature and pressure fluctuates continually. If someone flushes a toilet or turns on a tap, the darn thing just turns its heater off and spurts cold water. The Pressure switch appears to have no usefuyl effect whatsoever. In fact I've never managed to get hot water out with the Pressure set to "low" - the opposite to what I'd expect.
I assume this is a "normal" result of the mains water pressure upstairs being too low. The plumber (having been paid as part of a house extension contract) says there's nothing he can do. I find this hard to believe. My guess is that it could be improved by fitting a larger diameter pipe from the incoming mains supply and/or fitting a different shower - maybe with a header tank (although the roof isn't very high).
Suggestions welcomed.
Martin (South Cheshire)
