Hello,
I am in the process of insulating a kitchen in a granite home; at the moment all lathe and plaster has been removed from the walls and a nasty epoxy covering removed from the stone floors so I have an empty stone box. I plan to stud out the walls and insulate, that's another topic for the 'building' forum, but I'd also like to insulate the floor and stick laminate over top.
Please confirm (or otherwise) the robustness of my plan:
Sand or self leveller to raise low spots
Damp proof stone floor (plastic sheet?)
PIR insulation sheets straight onto plastic
T&G over top
Laminate, with either built-in or separate underlay to finish
Does this work? I see lots of other mentions of floating floors using wood frames or battens - why?
I have one external door to contend with, what's the minimum thickness of insulation that's worth doing?
Thanks,
JB
T&G over top
Thanks,
JB
