I am building an extension which has a number of rooms with a pitched ceiling. I am using Celotex insulated plaster board and would appreciate some advice on how I should best prepare the gaps/joints between the boards to prevent cracking. In other rooms, I filled the gaps with caulk etc and the plasterer applied mesh but I still have some cracks.
I am screwing the boards in place this time (approx 6" spacing) rather than using nails as I did before as I have had a few places where the plaster has popped around the nail head although I think this is more to do with movement of the timber rather than the nail failing and I suspect that even if I had used screws, the results would have been the same.
