I have some damp patches on the internal surface of the living room wall. The wall is also cold (exposed SW facing in Scotland). It is an external cavity wall, rendered. The cavity is clear of debris. The damp is 100% condensation, and the 3 patches match the location of airbricks on the outside. Humidity is already reduced in the house as much as possible (trickle vents, dehumidifier, extractor fans, lids on pots, bathroom door closed, etc etc).
The problem is the suspended floor is lower than the external pavement level, and the airbricks are not ducted/periscoped to the underfloor void. Instead, the airbricks flow cold air directly onto the inner skin of the living room wall, leading to (very) cold spots and condensation. Previous owner to blame I think. One airbrick does actually have a periscope, but I can feel that it's hanging loose in the cavity.
As the wall is cold anyway I have been considering fitting insulated plasterboard to improve the warmth in the living room. It will also help reduce the condensation on the wall by keeping the cold brickwork separate from the warm room. I know the best thing is to fit the ducting/periscope to the airbricks, but this requires removal of quite a few bricks in multiple locations. As I was considering insulating board anyway, I'm hoping it will do both things at once.
1. Is that a daft idea?
2. Do I need a vapour barrier between insulated board and the existing wall?
3. Can I fit the insualted board straight onto the existing brick/plaster wall, and then skim/paint the new board?
4. How do I 'blend' between the added plasterboard and the existing window surrounds etc?
5. I'll need to extend a wall socket out from the original wall through the new boarding. If the wires are too short, how do I proceed? Some of these? https://www.screwfix.com/p/ideal-in-sure-2-port-push-in-wire-connectors-pack-of-100/50427
Thanks.
Thanks.
