Hi folks - after a bit of quick rule-of-thumb advice.
We're converting a detached garage into a gym. Its a relatively recent single skin dense concrete block construction. Slate roof and we've bricked up the original garage door and have fitted a double glazed french door for access.
We've vaulted the ceiling so we're backing the ceiling plasterboard with 100mm cellotex/kingspan. No drama there, the thickness of the rafters dictates the insulation.
My question is about the walls. There is currently no insulation/cavity so we're going to dot and dab insulated plasterboard onto the (very dry) walls. I really don't want to have to batten the walls unless its unavoidable - though I do get a bit confused about moisture etc.
We don't want to lose too much space internally and I have a (possibly unnecessary) concern that thick insulated plasterboard is going to create a hassle when it comes to mounting anything on the walls - so I'm leaning towards a board with thin insulation (eg: 30mm), just as a nod to it being an insulated and usable (but not habitable) space.
All the advice online is based on it being a living space, so U-values seem a bit over cautions.
Just seeing if anyone had a suggestion on a sensible thickness of insulated plasterboard to use in this application? We have a small heater and a small air conditioner in there for the winter/summer months.
