Hi Guys and Gals,
First I would like to say hi as I have just stumbled across this site as I look for advice on the internerd with regards to fitting insulated plasterboard at home.
Basically I had an extension build only 6 years ago and have decided to make some alterations as I was never happy with the layout with the kitchen.
Upon removing the old wall tiles I found the walls were covered with basic insulated plasterboard which had been installed by dot and dabbing.
I removed all the plasterboard as the tiles had left large areas of damage when I removed them and also to make life easier when installing the new electrics.
Anyway, I was wondering if I actually needed insulated plasterboard in the first place. The walls of the extension are constructed with normal house brick on the outside and the inside is 100mm aerated blocks. The cavity between the brick and blocks is filled with rectangular rockwall insulation.
I am now in the process of preparing the wall for plastering and would like to know if I can just batten and board this wall with plasterboard or whether I would need insulated board again?
Secondly I am getting pretty confused with what I am reading as some sites say I need a vapor barrier etc?
If anyone could offer me advice, that would be very much appreciated.
Thanks in advance
Neil
Thanks in advance
Neil
