Hi All
I’m in the process of renovating a 1930s semi which is currently stripped back to brick as the plaster had blown on almost every wall in the house. I’m now struggling with which insulation methods to use due to the conflicting information on both the internet and by trades. The house currently only has insulation rolls in the attic which I will be adding more layers to. The house has cavity walls with no insulation, but the cavity is quite small at 35-40mm. There is a suspended wooden floor on the ground floor which I will be insulating with PIR boards forming an airtight seal with the floor above. This leaves the external walls to deal with. I was planning on using insulated plasterboard internally but I’ve read about lots of issues using this method regarding moisture behind and at the sides of the insulation. Additionally insulated plasterboard is a pain for hanging radiators and kitchen cupboards on. What is everyone’s thoughts? Should I insulate the walls or just leave them?
