Dear all,
I wish to add insulation to the inside of a 9" brick wall, and propose using plasterboard with 1" of Celotex bonded to it. Clearly the celotex is fixed to the wall, leaving the plasterboard exposed for decoration, but I have had several conflicting tips on the fixing of it. My questions are:-
1. What preparation does the existing plaster need?
2. What do I use to fix/adhere the insulated boardto the existing wall?
3. Are there any other considerations, e.g. ventilation between the old wall and the insulation, vapour barrier, etc.?
Regards, MM
Regards, MM
