It's a brick built conservatory with a polycarbonate roof.
In the winter it's freezing,summer it's unbearable hot.I have had complaints from neighbours about the noise (I'm a D.J and this is where my decks are).
The measurements of ceiling - 5m 50cm Length x 3m 20cm width = 17.6 m2
There is 10 internal beams which the polycarbonate roof is attached to 2 of them are plastic where the strip lighting is and the rest are timber.The spaces between each beam range from 38cm (smallest) and the other 7 are between 67cm - 76cm.
I have been told I should firstly insulate between the beams with rock wool then attach sheets of chipboard??
I was told plasterboard then plastered but I want to staple fabric to the ceiling creating a draped parachuting effect.Is chipboard better than plasterboard in order for me to do this?
Can anyone please advice me on this and if possible recommend materials/products for this job.
I would greatly appreciate it.
Thank You
Thank You
