- Joined
- 20 Nov 2010
- Messages
- 229
- Reaction score
- 21
- Country
I've recently taken on a bit of a project, and learning a few new techniques as I go, so any assistance greatly appreciated.
I have a 3.6x 1.7x2.4 bathroom with a slightly pitched flat roof. I've ripped the ceiling out and the bathroom is going to be replaced.
My rafters look like about 3 inch high and the roof is Stirling boarded. Looks like it has been replaced recently, but not the rafters which are no brilliant but ok.
I want to know what I should do to insulate the roof. Can I put celotex right up against the board tight or should I lay it under the rafters. I intend to make up the 160mm required. Do I need to add a vapour membrane or allow ventilation?
What should I use to attach the celotex? Bearing in mind any screws are likely to be 160mm long? Or 160 minus the 3inch if I can go up against the board?
When applying the plasterboard onto the celotex, can I just screw to the celotex or do I need to screw through to the rafters?
I also have a kitchen extension uninsulsted with a pitched roof. This is felt and asbestos cement tiles. Again, can I just insulate up to the felt or do I need to leave an air gap?
Thanks in advance!
James.
Thanks in advance!
James.
